EISA Best Streamer 2026–2027
Primo Plus
Dual-mono streamer DAC with balanced outputs and a preamp mode.
5.0 · 2 reviews
€1,199
Volumio Primo Plus seen from the front left, with its two knobs and the small OLED display.
The highlights
  • 2×ESS ES9039Q2M DACs, one for each channel
  • 768kHzPCM at 32-bit, plus DSD512
  • 90fshigh-precision master clock
  • 8+ NOSDAC filters, or none at all
  • 6.3Vrmsbalanced output, with a preamp mode
  • 4KVolumio on your TV over HDMI
Primo Plus on a white shelf next to a small plant and a green glass vase.
Designed and assembled in Florence, like every Volumio device.
Reviews
What owners and reviewers say
EISA Award, Best Product 2026–2027, Streamer: Volumio Primo Plus
EISA Awards 2026–2027
Best Streamer
“…the technology inside this streaming DAC is entirely new.”
From the EISA jury’s verdict. Read it in full
From owners
5.0
2 reviews on shop.volumio.com
  • “The level of detail in the sound is truly impressive.”
    Seok Ju Lim · March 2026
  • “I am pleased with the Sound of the Primo plus, very detailed…”
    Marcel Moris · January 2026
Read all 2 reviews
Look inside
Every part has a job
Primo Plus was designed from scratch around cleaner power, lower noise and a more precise clock. Pick a part to find it on the board.
The Primo Plus main board, with each section named on the board: control unit, low-noise LDOs, dual mono DAC, master clock, digital and analog linear power supplies, and the op-amp dual power supply.
Sound
Tune it to your system
Eight filters, or none
Pick one of eight digital filters to fine-tune the sound, or switch to NOS mode to turn oversampling off.
Eight output levels
Match the input of any amplifier. Or use the built-in volume control and connect Primo Plus straight to a power amp.
Level 1Output in VrmsLevel 8
Connections
Plug in everything
Stream over the network, or connect a computer, a TV, a CD drive or a hard disk. Then send the signal out balanced or unbalanced.
The back of Primo Plus on a shelf, with its audio, network and USB connections.
In
Network
Gigabit Ethernet or dual-band Wi-Fi, up to PCM 384 kHz / 32-bit
USB-C
From a computer, up to PCM 768 kHz / 32-bit and DSD512
Coaxial and optical
RCA and TOSLINK, up to PCM 192 kHz / 24-bit
USB-A × 2
Flash drives, hard disks and CD drives
Bluetooth
Bluetooth 5.0
Out
Balanced
XLR, 1.00 to 6.30 Vrms
Unbalanced
RCA, 0.50 to 3.15 Vrms
USB
To an external DAC, up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off
HDMI
The Volumio interface on your TV, up to 4K at 60 fps
Trigger
12 V on a 3.5 mm jack, to switch your amplifier on
Premium features built in
All your music, one player
Primo Plus has every Premium feature built in: TIDAL and Qobuz with Connect, Spotify Connect, AirPlay and HighResAudio, plus your music library, your CDs and internet radio.
They belong to this Primo Plus, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
A living room with a TV on the wall showing album art, two speakers on stands and Primo Plus on a low shelf with records.
On your TV
Connect HDMI and browse your music on the big screen, in up to 4K. Nova, the new Volumio interface, is on its way.
Discover Nova
A listener pointing the Remoto remote at Primo Plus, with the TV showing the album playing.
In your hand
Use the Remoto remote that comes in the box, or the two knobs and the OLED display on the front.
Primo Plus
Tech specs
Audio specifications
DAC
2 × ESS Sabre ES9039Q2M
DAC filters
8 digital filters for fine tuning
Supported resolution
Up to PCM 768 kHz / 32 bit and DSD512
NOS mode
Switchable ON/OFF
Master clock
High-precision clock with ultra-low phase noise (90 fs) and jitter
Preamp
Hardware gain control to drive power amps directly
Power supply
LC filtering and dual linear stage with dedicated line regulators for analog and digital paths
Network input
Up to PCM 384 kHz / 32 bit
USB-C input (device)
USB-A input (host)
USB Flash Drive and HDD/SSD
USB output
Up to PCM 1536 kHz / 32 bit and DSD1024 (DSD256 with multiroom enabled)
S/PDIF coaxial input
Up to PCM 192 kHz / 24 bit
S/PDIF optical input
Analog unbalanced output
0.50, 0.775, 1.00, 1.50, 2.00, 2.50, 3.00, 3.15 (Vrms)
Analog balanced output
1.00, 1.55, 2.00, 3.00, 4.00, 5.00, 6.00, 6.30 (Vrms)
Analog output impedance
≈140 Ω
Supported formats
Supported services
UPnP/DLNA
Plugins
Hardware specifications
USB
1 × USB-C device, 2 × USB-A host (5 V / 0.56 A; 5 V / 1.33 A)
1 × RCA
1 × TOSLINK
1 × XLR (stereo)
1 × RCA (stereo)
Video output
LAN
Gigabit 10/100/1000 Mbps
Wi-Fi
Bluetooth
5.0
CPU
Cortex-A72, Quad Core 1.5 GHz
RAM
2 GB LPDDR4
Internal storage
16 GB eMMC
Trigger out
1 × 3.5 mm jack (12 V, positive on tip)
Knobs
2 rotary encoder knobs with push-button
Display
1.3-inch OLED display, adjustable brightness
Remote
Remoto IR remote control (included)
Power
5 V DC / 3 A
Power input
Dimensions
27 × 15 × 5 cm
Weight
2.25 kg
Primo Plus from the front, next to the Remoto remote.
In the box
  • Volumio Primo Plus
  • Remoto IR remote, battery included
  • 5 V / 3 A power supply
  • NFC and QR code information card
Read the user manual
Specs from Volumio's spec sheet, October 2026. Dimensions, weight and finishes from shop.volumio.com.
